Heat Pump
Heat Pump
Is my heat pump OK?....... This morning I noticed some frost on my condenser while in a Heat mode. Is that normal or is my defrost timer going bad. Any idea?
Normal unless it stays on there constantly. Keep a eye on it to make sure your unit does go into defrost occasionally. Different manufacturers utilize different methods to determine the correct time to run the defrost cycle. You are probably OK.
