Heil Heatpump blows cool air
Hello all. I'm having a problem with my heat pump not working correctly.
It blows cool air when the heat is supposed to be running.
In emergency heat mode the same thing happens.
I have very (literally) limited knowledge on how these things operate and was wondering if any of you guys could give me some pointers on what to look for.
Hmm....
No heat in heatpump mode or emergency heat mode?
These are different modes of operation. In normal (heatpump) mode the fan runs and the outdoor unit provides heat. Electric heat comes on in defrost for the outdoor unit. This is called AUX heat and is the same heater that comes on in emergency heat.
Sounds like a tstat problem to me.
Do you have a volt/ohm meter? And do you know how to use it?
