No More Emerg Heat...
Old 01-05-08, 09:03 AM
T
Coleman HP & AH
Programmable honeywell tstat
Been having troubles getting 24v to the contactor, finally got that resolved. During that time, we would use emergency heat to bring the temp up a few degrees.
NOW, the air handler will not come on in any of the auto modes. No cool, no heat, or em heat. Fan will turn when switched ON instead of AUTO on tstat, AH also comes on when jumping R+G at tstat, but no heat.
This thing has kicked my butt since June when I originally replaced the HP fan motor. Please help, as I'm about to take up a career in arsony.
Old 01-06-08, 05:12 AM
Jay11J's Avatar
What is the model # of the t-stat?
What happens when you jumper Y and R at the t-stat?
Old 01-07-08, 04:41 PM
T
Honeywell CT3611
Jumping Y and R does nothing.
Old 01-07-08, 05:20 PM
Jay11J's Avatar
Odd that the fan would work. but nothing else.
What contactor were you having trouble with, in the air handler or the unit outside?
Old 01-07-08, 09:04 PM
T
In the outside unit. As it turns out, the new contactor still did not get pulled in after all that. I was in the process of troubleshooting one of the relays when this new problem started.
Old 01-08-08, 04:50 AM
Jay11J's Avatar
If we got the fan to work on R and G, we got power..
Go to the air handler and check the Y wire to make sure have contact/power. If got power there, then go to the outdoor unit to check for low voltage goign to the unit.
Old 01-08-08, 03:59 PM
Ed Imeduc's Avatar
Wink
Im with Jay at the tstat if you jump R to G you should have FAN . R to Y the compressor should come on. R to O/B should work the 4 way valve. Soooo is it in the tstat or in the 24V wires in the unit
