no heat
Old 01-27-08, 10:58 AM
no heat
i have a goodman 3 ton central air conditioner and last night the heat stopped coming on. the unit does nothing, no fan or anything. i tried to turn on the a/c and it did nothing either. when the temp drops the thermostat does "click" like its trying to come on. i check the breakers and seems to be ok. please help, its getting cold.
Old 01-27-08, 01:48 PM
Jarredsdad's Avatar
Is your tstat battery operated or hardwired?
If battery powerd you may have lost the transformer in the indoor unit or blown a fuse on the indoor control board.
Old 01-27-08, 02:11 PM
the thermostat is battery powered. i looked inside the indoor unit and seen a small 3a fuse, it was good. anyway to check the transformer?
the unit is only 6 months old btw.
Old 01-27-08, 03:26 PM
Jarredsdad's Avatar
Yes, primary side and secondary side. With volt meter see if 24 (or so) is coming from secondary side.
Kill power and disconnect the trans. Ohm each side if it's open it's bad.
Old 01-27-08, 05:18 PM
where is the transformer located? i can check the volts, but you lost me on the ohm stuff, lol.
