How to Wire up Baseboard Heater
Got 2 baseboard heaters from homedepot today. 1 -30" and 1-6ft. I will be wiring these in a line. Into 30" and out to the 6ft.
How do i wire these up? I have my 240 Volt circuit and wires are in place but im not sure where to connect the wires. I will be running the 30" one first and then from there into the 6ft heater.
This is what it looks like:
Left side
Right side
Left side
Right side
What Matt and Jarredsdad said! But also, you say you plan to wire from one heater to the second one. Be SURE you don't wire the second heater in series with the first one. That's a great link Matt posted and the last pic shows the two heaters wired in parallel.
If you don't know the difference between parallel and series wiring, be sure you check it out before wiring two heaters together.
