Goodman Heat Pump
Goodman Heat Pump
Quick question, I have a Goodman Heat Pump and when we run the heat is the outside unit supposed to run. I get heat but just with the inside fan running. I just need to now if the compressor fan on the outside is suppose run also. It doe work when we use the air. Thank you in advance.
Yes, the condenser is supposed to run in heating mode, you may have looked at it when it was in defrost, the fan won't run during that time.
If the outdoor unit doesn't run at all during heating there is a problem.
Yes it should be running in heat mode. You obviously have another heat source also known as emergency (em) heat or auxiliary heat. Most multi heat source thermostat used for heat pumps allow you to switch exclusively to your em heat source, so check first to be sure you're not doing that, and let us know.
