Upgrading to a Digital thermostat
Old 12-09-09, 03:57 PM
Upgrading to a Digital programmable thermostat
For electric baseboard heat.(240) It's my understanding I need a double pole programmable thermostat. From doing a little research on them, there seems to be very little options for my needs.
My question and concern is, the old thermostat is located in my living room. It controls two baseboard heaters, one in my living room and the other in the kitchen.
I noticed the ratings on the thermostat I looked at are rated from 3800-4000 watts. In some cases even lower.
I looked at the specs on both baseboards and the rating on them are 2500 and 1500.
Do I need a stat with a rating of 4000 watts or more for my setup? I'm confused...
Thanks
Old 12-09-09, 07:19 PM
Jay11J's Avatar
You don't have to have double pole, it just gives a positve shut off. (No power going to the baseboard)
Yes, you need to get a stat that be able to handle the wattage.
Old 12-09-09, 07:49 PM
I meant in terms of codes
I've spent a few hours searching online and I've yet to find one that could handle the load of 4000+. Not sure if they even make them?
The baseboard in the kitchen reads 1500/1100. What exactly does this mean?
One other question. It appears that the current therostat is a two wire system. Do I need to replace it with a two wire thermostat, or can it be a four wire system?
Old 12-09-09, 08:41 PM
Jay11J's Avatar
If it's code, then you should do the DP t-stat.
I did a quick look and only found non-program t-stat that can handle that much wattage. I'm not sure why that is...
First set is for 240 volts, and other set is 208 volts.
If it's two wire, then it's not a double pole. It may not of been code at the time, now from you said, it's code to ahve a double pole. Was that for your area? If it's not code for your area, then you don't need to do double pole.
Double pole= 4 wire t-stat
Single pole= 2 wire t-stat.
Old 12-10-09, 03:31 PM
I actually found some on amazon and few other sites. They handle loads up to 4000, which is what both baseboards combined total.
They should be ok right?
Old 12-10-09, 05:33 PM
Jay11J's Avatar
Yeah, as long you are with in range, you should be good to go!
Old 12-10-09, 06:22 PM
Great! Thanks for all your help.
