Changing A Heat Strip?
Old 12-19-09, 01:26 PM
Hello,All
So glad I found this message board I'm sure I will have a lot to contribute.I do tho have the resaon I found this site.I'm taking out a 5k heat strip and want to change it to a 15k it doesn't seem to hard to do.Are there any special things I should know when doing this.Thanks for your time.Beer 4U2
Old 12-19-09, 02:10 PM
airman.1994's Avatar
Received 3 Votes on 3 Posts
5k is very small. 15k is a very big jump. How many CFM is your AHU?
Old 12-19-09, 04:19 PM
Houston204's Avatar
Received 10 Votes on 8 Posts
You will need to pull wire and add an additional breaker.
Old 12-19-09, 06:06 PM
Thank you Houston,I didn't think off that.but I will make sure to get the proper gage.
Its 1200cfm.Is that to small?Should I only go up to 10k?I have to have a temp of 68 degrees 3feet off the floor and all my air is being pulled straight from outside.I also have a 1200cfm exhaust fan blowing air outside.I just need to get it as warm as possible.thanks again for your time.
Old 12-19-09, 10:10 PM
1200 cfm will handle the 15k. But I don't think 15k will keep it at 68. I.m no expert on GA weather but I think you need to step back and do a heat load on the space so you can size the heat.
Old 01-06-10, 10:50 AM
I just opened it up and it's a 10k not a 5k like I thought. It's a Goodman A.H.It will bring the room to 61F but I need it to be 68F any suggestion on how I can do this before I change The strip?also It has two 8g wires running to the heat strip.Will I have to run two new Larger wires or can I just run two more 8g wires from two new 20 amp breakers.
Thanks again for your time.
Old 01-06-10, 11:39 AM
Tolyn Ironhand's Avatar
Received 47 Votes on 40 Posts
At 10KW you are looking at 42 amps. You will need at least #6 wire and a 60 amp breaker. If you use the 15KW heater is 63 amps. You will need #4 wire and a 70 amp breaker.
Old 01-06-10, 12:10 PM
dun11's Avatar
It's a Goodman A.H.
Do you have a heat pump with an elec back up heat kit or a straight elec furnace?
Old 01-06-10, 01:09 PM
I believe that I do have a heat pump because the copper tube heats up.(is this correct)The label wasn't marked clearly marked.
thanks for your time
Old 01-06-10, 01:13 PM
It now runs on two 20amp breakers running on sepreat wires that are both #8. thanks
Old 01-06-10, 01:45 PM
Then something is not right because if it is 5KW it will draw 20.8 amps at 240 volts. If it is a 10KW it will draw 41.6 amps. You said it is a 10KW so the 20 amp breaker would only hold for a very short amount of time. The numbers are not adding up. Why would they wire it using #8 if it is on a 20 amp breaker? Is it 2 (or 3) - 20amp two pole breakers?
