Condensor not coming on
Old 03-21-10, 09:01 PM
My unit: RUUD UPNE-036JAZ Heat Pump
The condensor (outside) to my RUUD Heat Pump is not coming on. I tested the thermostat, and it seems to be working ok. When I depress the relay, the condensor fan turns on but shuts down again when I release.
I noticed that the circuit board (under the unit's housing) has two small red lights. The one on the right is blinking. What does that mean? Do I have a bad circuit board, or is my coolant level low?
A manual for the heat pump would be great if I could find one.
Thanks!
Old 03-22-10, 04:45 PM
Jay11J's Avatar
Go to page 15 of the Manual, to see the code of the two LED light.
Old 03-23-10, 11:30 AM
condensor not coming on
Thanks.
Do you know if there is a way to "re-set" the circuit board?
Old 03-23-10, 06:35 PM
the red light manual should be on one of the backs of the doors on the heat pump
Old 03-23-10, 07:10 PM
Houston204's Avatar
Received 14 Votes on 11 Posts
To exit the lock-out mode, remove 24 volts to the defrost control by removing power to the indoor air-handler/furnace or by shorting the two defrost control test pins together.
