Best heat pump thermostat settings.
I a used to a gas furnace and programmable thermostat. I now live in AZ and have a air to air heat pump, should i set the temp back at night? It takes 3-4 hours to bring inside temps up from 68F to 72F. I am thinking maybe just leave it at one temp all the time.
I leave the temperature settings set at 71 degrees during the Winter and 82 degrees during the Summer. I set the humidity to 48% both Summer and Winter.
When we go on vacation in the Summer, I set the AC to 85 degrees. In the Winter I set the temperature to 65 degrees when we are on vacation. Bill
