Heat pump with electric back up heat wiring help
Old 12-01-10, 04:04 PM
Hello all,
I am installing an electric heat kit into my air handler and need some help with wiring changes. Below is what I have currently but need to know how to wire the thermostat with the new heat kit. Also, are there any changes that need to be made to the electroic board in the handler? Thanks for all the help
Thermostat - Honeywell RTH7400
Air Handler - Goodman AEPF183016
Heat Pump - GSH130301
Tstat Air Handler
C--------blue-------C
G-------green-------G
Y-------yellow------Y/Y2
O/B------white------O
R/Rc------red--------R
Aux
E
L
Old 12-02-10, 07:36 PM
Jay11J's Avatar
What's the mode # of the kit?
For now till I know the kit #
T-stat--------------AH
G-------green------G
O/B-----white------O
R/Rc-----red--------R
Aux------??--------W/W2
E---------??--------E/W1
Old 12-02-10, 11:23 PM
F
I figured if Jay don't mind me step in here as well due I am well versed with electrical system.,
Ok when you add the electric heat strip in there how big this unit and did that unit have addtional breakers for electric heat and did the cable or conductor is sized to handle addtional load ??
This part is crictal to prevent any damage to your unit.
As far for your thermosat cable you should have either 7 or 8 conductor thermosat cable due the number of connection you will need for aux heat.
Merci.
Marc
Old 12-03-10, 05:22 AM
Jay11J's Avatar
Who said I wouldn't mind? :-) No, I don't mind at all. We are here to help out as a team.
