Heat Pump Starting and Stopping
Old 05-23-11, 05:37 PM
Hello. I had a heat pump installed this winter. It was frozen sollid for a time, until the Tech. figured out that he did not connect the defrost circuit. Went through the winter with no further problems, but this spring, tried the a/c for the first time and here's what happens: It runs and cools for about 5 minutes, then kicks off. Several seconds later, the fan and compressor seem to start, but for just a second. Then both kick off again for several seconds, then on for a second, then off, etc. Would much appreciate any advice on what might be causing that. Thanks!
Old 05-25-11, 07:45 AM
might have a low pressure switch that would cause that if freon is low whats the name brand?
