Heat pump keeps running
Old 08-03-11, 02:05 PM
my central heat pump indoor unit keps running but the outdoor unit cycles on and off.
The last two days the outside air temp was 100F degrees. The thermostat was/is set at 79F but the room temp never went below 83F until around 11:30PM when it cooled off outside.
Is this normal for the temp conditions?
Thanks
jawjajon
Old 08-03-11, 03:22 PM
hvactechfw's Avatar
Received 2 Votes on 2 Posts
system charge and operation needs checked by a professional. No it is not normal.
Old 08-05-11, 11:44 AM
heat pump keeps running
Thanks! I had a similar problem last winter. Tech said the system coolant was out of "balance". and added more.
I'll call him again!
jawjajon
