kickspace heater
Old 09-15-11, 04:43 PM
A
kickspace heater
Hello,
I need to add some extra heat into a basement model railroad room. The walls will be covered by benchwork that house the railroad. The entrance to the room is about 6 foot wide with area above it maybe install a kickspace type electric heater. I could always install it below the benchwork to wash the floor with warm air. Any suggestions would be appreciated.
Thanks
Old 09-15-11, 05:05 PM
hvactechfw's Avatar
Received 2 Votes on 2 Posts
heat rises. I would say on the floor would be better.
Old 09-15-11, 05:16 PM
A
I thought the same. My concern was how hot the air would be coming from the unit and if it would be uncomfortable on people's feet.
Old 09-15-11, 05:22 PM
hvactechfw's Avatar
it would be an electric heater with a fan basically. I particularly like warm feet while in a cool space.
Old 09-16-11, 12:49 PM
G
Received 13 Votes on 13 Posts
Check the manufacturers, such as Broan - their websites will have lots of installation tips. You can get one with a 2-speed fan and a thermostat.
I would consider, instead of an electric kickspace heater, just a small fin-tube baseboad unit - might be a little easier to install.
Old 09-16-11, 06:08 PM
A
I guess that one or two electric hydronic baseboard heaters would be a good choice.
Thanks for the replies.
Old 09-16-11, 09:29 PM
A
Another option I was thinking of was using radiant cove heating. Does this sound like a viable option?
Old 09-17-11, 08:31 AM
chandler's Avatar
Received 6 Votes on 6 Posts
Another solution would be thermostatically controlled ceramic heaters. Very cost efficient, small, and they put out a good bit of heat, fan forced, and safe to use.
Old 09-17-11, 10:51 AM
G
Originally Posted by chandler View Post
Another solution would be ceramic heaters. Very cost efficient.
All electric resistance heaters are 100% efficient. 1 kWh = 3412 Btu
