Electric Furnace Not Always Turning On
Old 11-05-11, 02:04 PM
C
We have an electric furnace heating our house. Sometimes when we are heating, the furnace will not kick on by itself although it's colder than the thermostat is set to. We bought and installed a new thermostat and still the same problem. We have to turn the breaker on the power box off then on and then the furnace will turn on if it's colder than it's set to. This does not happen when cooling. When heating, most of the time it will turn on itself but it seems maybe once a day it will not. Any clue what our issue is?
Old 11-05-11, 07:23 PM
Jay11J's Avatar
Going to need more info from you.
What is the make and model # of the air handler, and also t-stat.
Old 11-08-11, 04:14 PM
C
The furnace is an Intertherm (believe also known as Nordyne) model # C1QA-030U-B
THe thermostat is a Hunter model # 44155C
Old 11-08-11, 06:54 PM
Jay11J's Avatar
I am not able to find a diagram on your model. Can you take aphoto of it and post it here for us?
Thanks!
Old 11-09-11, 01:31 PM
C
Found another number on the bottom half that may be the right one - FEBB-012HA. If you still need a pic, let me know.
Old 11-09-11, 01:44 PM
C
I ws told it may be the sequencer sticking. Where would this be and would it be easy to replace?
Old 11-09-11, 07:43 PM
Jay11J's Avatar
yes, I've heard of this happening.
They are in the air handler where all the wires joins up, and should be easy to replace.
