Heat Pump Noise Issue
Old 11-07-11, 11:34 AM
G
I'm hoping someone can provide some help with my heat pump issue. I'll try to explain it as best as I can.
This past summer we had a new 2-stage SEER 16 Heat Pump installed (not geothermal). We used to have a single zone in our townhouse but we had a second zone upstairs added. It has been working great till we switched over to heating now that the weather has turned colder. The heat pump heats both zones great and seems to be working well overall. The only problem is whenever it kicks on the unit outside is very noisy. It rattles rather loudly then after a minute or two it quiets down and you really don't hear it running then. I had a contractor look at it and he explained from what I understand that the refrigerant is having to heat up quickly to get the heat pump running and that is very common. What's puzzling to me is since our heat pump is running fairly often with the cold weather I would think the refrigerant would keep warm and not have to heat up per se each time therefore causing the rattle. I had him check the unit's balance and that is fine too.
Can anyone give some feedback on this? Is this common? Can it be quieted? Any help would be greatly appreciated.
Old 11-07-11, 12:43 PM
airman.1994's Avatar
Received 8 Votes on 8 Posts
One thing to try is a band heater on the comp. This has helped in a few cases. Also Copland has an issue with there 2 ton comps. The replacements will not be ready tell Feburary. I have not seen an issue in any other ton.
Old 11-08-11, 03:22 AM
G
Smile Thanks for replying!
Thank you for your helpful information! Do you know how much a band heater costs? Can I install it myself (I'm not too heat pump savvy) or will I need a heating contractor to install it? Will it work on any heat pump? I have a 2-stage Bryant Heat Pump.
Thank you again!
