How to Disable A/C on home heat pump unit?
Old 11-07-11, 01:39 PM
Anyone know how easy it may be to disable the A/C feature on a home heat pump?
I have a unit where the the A/C condensates too much in the furnace/blower and isn't worth hassling with so I'd like to just disable the A/C feature (to keep someone from accidentally turning it on).
Any chance one of the wires in the thermostat/control unit can just be disconnected and it will run heat just fine?
And I'm not in front of the unit, but it's a Honeywell.
Very similar to this unit but it also has 2 sliders for the Fan and Heat-A/C selection.
(Honeywell T8600D2069 Thermostat Chronotherm IV Plus Deluxe Programmable-White T8600D)
Old 11-07-11, 04:05 PM
Jay11J's Avatar
No, there is no way with out disabling the heat mode.
I don't follow?? Are you having water getting into the system?
Is the drain cleared?
Old 11-08-11, 11:16 AM
The radiator fins get clogged and condensate and the air-flow blows the water against the walls of the unit before it can drain causing all sorts of issues. (And yes, no manner of cleaning by me or pro's seems to resolve the issue.)
After poking around on the inter-web, I'm told I can just un-wire the A/C circuit on the rear of the control panel which should disable the control panel from being able to close the relay should someone attempt to turn the A/C on. Any downside to this that I'm not being told?
Old 11-08-11, 12:11 PM
Jay11J's Avatar
What is the coil getting clogged up with?
Unwire what? For the HP the compressor run on Y in either heating or cooling.
What are you using for A/C in the summer?
Old 11-08-11, 01:14 PM
Clogs with fine dust. Filters are the old metal screen type.
Don't need A/C - it's hot for 5 days each year.
As for the unwire part, that's what I'm inquiring about. I'd love to find out their are relays for Heat, Emergency Heat, A/C and I can just disconnect the A/C lead to the relay - but I might be dreaming.
Old 11-08-11, 05:16 PM
Jay11J's Avatar
Get rid of the metal type filter, and upgrade to starting grade pleated filter.
if the coil is plugging up, it affect the HP in heating mode.
There is no other relay on the compressor. Y hook up starts the compressor in heat and cooling mode.
Old 11-08-11, 05:31 PM
airman.1994's Avatar
Received 8 Votes on 8 Posts
I agree with jay! Washable filters are junk. Clean the coil and add a good filter.
Old 11-11-11, 05:43 PM
Jarredsdad's Avatar
Hello - remember Me?
First if you are having condensate issues and are using a washable filter your evaporator is probably all kinds of clogged up. With whatever fine dust crap, your drin line is also probably clogged up.
The evaporator can be cleaned with chemicals that are pretty cheap. If you have a wet dry vac, suck on the primary drain form it's end point outside of the home.
As far as your question goes (IF IT ISN'T A Rheem or Ruud), yes you can disable the A/C and only have heat. Your stat is junk, so I won't even begin to explain that part.
However, if you remove the stat and disconnect and tape the wire on the "O" terminal, or do the same at the airhandler or out door unit. The unit will only work in heating. The unit will, independent of the stat, cycle into A/C mode for defrost because this is controlled by the whatever type defrost control is in the outdoor unit.
I always try to answer the question asked if it is safe enought for Joe DIY.
Chris
Old 11-11-11, 05:48 PM
Jay11J's Avatar
Well, hello! I just tried to send you a pvt message, but your box is full!
Old 11-12-11, 06:27 PM
Jarredsdad's Avatar
Surprised me, just cleaned it up. And, unfriended me on FB? I will not be at the wedding!
