Line Voltage baseboard heat with 24V relay
Old 04-09-12, 01:45 PM
R
I'm replacing 30 year old thermostats on my line voltage baseboard heat system. The Great Room zone has two breakers feeding a White-Rodgers box which has the thermostat wire leaving it. Thermostat wire has red and white wire attached, green wire not attached. Old thermostat did not require a c wire but its replacement will. My question is how can I turn the available green wire into a c wire?
White Rodgers | Flickr - Photo Sharing!
Many thanks.
Old 04-12-12, 05:51 AM
Jay11J's Avatar
Do you have a model # on this WR box?
Old 04-12-12, 12:11 PM
R
The model number on the label is 44-3012
but it is about 25 years old.
photo | Flickr - Photo Sharing!
Thanks
Old 04-12-12, 01:09 PM
Jay11J's Avatar
The green wire from the transformer that is going to two white wire w/ wire nut. You can use that as your "C" hook up. So use the unused t-stat wire to that, and match that same wire to C at the t-stat.
Old 04-13-12, 06:06 AM
R
Thanks, I thought that may be the case. The output of the White-Rodgers unit is 18 v.a.c at .42 amps, and I'll likely use a modern low voltage thermostst (such as the Nest) which calls for 24 v.a.c (+/- 15%) at 100mA. Do you think the Nest's tolerances are as advertised and the 18 v.a.c won't be sufficient to power it, or a similar 24v unit?
Old 04-13-12, 06:30 AM
Jay11J's Avatar
Take a voltag reading on it and see what it is putting out for voltage.
Old 04-13-12, 06:56 AM
R
Good idea. I do that by putting one probe on the green thermostat wire and the other probe on the white one? After connecting the green thermostst wire as you described below of course.
Old 04-13-12, 07:04 AM
Jay11J's Avatar
Between Green and Red. You don't need to hook up the green t-stat wire yet. Just insert the probe into the wire nut.
Old 04-13-12, 08:12 AM
R
OK, now I'm making some progress, thanks to your generous help. My new multimeter tells me the circuit is putting out 25 volts. I think I have just one last question: When I connect my available green thermostat wire to the green wire coming out of the transformer do I add the green thermostat wire to the existing green/white/white (making it green/green/white/white in the wire nut) or do I remove the green wire coming from the transformer from the two white wires and have green/green in one wire nut and white/white in another?
Many thanks.
Old 04-13-12, 12:12 PM
Jay11J's Avatar
Just wire the t-stat into the wire nut w/ the green, two white wires.
