Help Decoding Serial Number on Heat Pump
Could someone help me figure out the manufacturer, manufacture date, size and SEER rating for this unit?
Thanks for any help!
ICP = Manufacturer
5 ton or 60,000 btu
made in 2004
10 seer
http://icpindexing.toddsit.com/docum...2821300108.pdf
5 ton or 60,000 btu
made in 2004
10 seer
Thanks for the help! This unit is installed on my rental house in Phoenix. It is a one-story, 1600sf built in 1988. Does this seem way too big?
We just moved in and noticed that we are using a little over 100 kWH per day while keeping the thermostat at 77. Could this be due to the a/c? Our neighbor with a similar size house uses about 55 kWH per day (not sure of his thermostat habits though).
A load calculation is the only way to know what size unit your home actually needs. Just guessing is not acceptable when sizing equipment. As to your home being in Phoenix I could see it needing 5 tons depending on windows, doors, insulation.... but I can't tell you for sure if it is oversized. There are DIY load calc software available on the internet that you can purchase for one time use.
