5a fuse blows when cooling engages.
Old 07-14-12, 10:30 AM
P
The 5a fuse blows when unit kicks into cool mode. Checked tstat wiring. Looks ok. Thought it might be contactor coil, replaced fuse, isolated coil wires, fuse did not blow. Thought I found the problem, so changed the contactor, turned it back on and it blew. I am thinking reversing valve coil maybe? Any tips to further diagnose? Any tips to by pass to get it to work over the weekend would be great to...
Old 07-14-12, 11:02 AM
Houston204's Avatar
Received 17 Votes on 14 Posts
Does your new contactor have a 24VAC coil?
Do you have an ohm meter?
You want @ 12 to 16 ohms on those 2 coils.
I've seen 3 ohms pop fuses.
Any shorts in the outdoor unit?
Does the fuse pop when you run the heat pump in heat mode?
Old 07-16-12, 04:11 AM
P
Update. Ran for all day Saturday, half day Sunday, then fuse blew again. I am thinking I have a problem with a wore wire somewhere. There is no specific function that makes it blow the fuse. That would make it too easy...
