removal of old electric wall heater
Old 10-20-12, 11:29 PM
T
See picture with 2 arrows. There is a butterfly like steel plates that seems to be bolting the unit (electric heater) to the wall.
I was told that such items have 2 screws at the back holding the plates together. How do I remove the plates so that I can remove the unit?
Thanks.
Old 10-20-12, 11:35 PM
Received 1,480 Votes on 1,368 Posts
Those silver wings are the connector. Yes there are two screws behind the heater on that clamp. No....that clamp/wings has nothing to do with holding the heater to the wall. Look all through the cabinet. You should find screws holding it to the wall. Once the heater is removed from the wall you can get to the wire connector.
Old 10-22-12, 10:28 AM
T
Yes. I did miss a screw. Once I removed the heater, there is 2 screws holding the clamp. Thanks much!
