no heat please help
Old 11-16-12, 02:58 PM
no heat please help
it was working fine then next time i turned it on the blower motor doesn't kick on properly it starts turns 3-4inch then stops and continues the same process turns 3-4 inch and stops but never kicks on all the way turns freely when i spin it without power so i don't know if it's the motor . a relay . or what . the units an all in one every things contained in the unit blower motor , condenser etc. it's a nordyne model # 6p5rd, please help
Old 11-16-12, 03:29 PM
Hi I'm new here but mabe I can help.
you say a motor starts and stops does this motor a psc which means does it have a starting capacitor. they also have a run capacitor it sounds like the capacitor might be faulty.
Old 11-16-12, 03:33 PM
yes it has a capacitor one of the three pronged ones you think that may be the problem
Old 11-16-12, 03:49 PM
that would be my suggestion first. If you have voltage at the motor and its not turning this would be one of the things i would check for first.
Old 11-16-12, 03:54 PM
ok thank ill try that and ill getback to you in a few days & let u know if it works for me thanks for your help
