Need help installing a new Honeywell RTH3100 Thermostat
Old 01-27-13, 11:44 AM
I have a Trane system (two stage heat and one stage cooling) with Air Handler Model TWE065E13 with (Control Board 21C148502P01). The system seems to be running for prolong periods and thermostat doesn't seem to post accurate temp. I thought I would replace the old Honeywell Chronotherm IV Plus thermostat with a non-programmable Honeywell RTH3100C, but the wiring doesn't quite match. I actually have a second programable RTH6580WF in case the manual one doesn't work out.
The current wiring configuration (with old TSTAT) is as follows:
Thermostat Terminal "C" ( Blue wire) Terminates on "B" control board
Thermostat Terminal "R" (Red wire ) Terminates on "R" control board
Thermostat Terminal "W2" (White wire) Terminates on "W1" control board
Thermostat Terminal "E" (Black wire) Terminates on "W2" control board
Thermostat Terminal "W1" jumped to Thermostat Terminal "Y1"
Thermostat Terminal "Y1" (Yellow wire ) Terminates on "Y" control board
Thermostat Terminal "O B" (Orange wire) Terminates on "O" control board
Thermostat Terminal "G" (Green wire) Terminates on "G" control board
Thermostat Terminal "W2" ( White wire) Terminates on "W1" control board
Unconnnected Brown wire in Thermostat Terminates on "T" control board
Thermostat Terminal "X1" nothing connected
Thermostat Terminal "L" nothing connected
Thermostat Terminal "X2" nothing connected
Thermostat Terminal "QT" nothing connected
Control Board Terminal "Y lo" nothing connected
Control Board Terminal "W3" nothing connected.
The new Honeywell RTH3100C has the following terminals.
E, AUX, Y, G, O, L, R, B, C
Thanks to anyone that can help.
Old 01-27-13, 05:40 PM
hvactechfw's Avatar
Received 2 Votes on 2 Posts
Old = New
R = R
C = C
w2 = AUX
E = E
Y1 = Y
O = O
G = G
Change function 6 and 8 in setup to 3 (trust me)
Old 12-14-13, 11:03 AM
Chronotherm 3 to Honeywell RTH 3100c1002
similar to above question, but it appears I only have six wires.
Old themostat shows.......
red to red
c to blue
yellow to yellow
green to green
white to w2???
orange to E.???? (Maybe the last two are switched around...can't tell)
So if 3100 has
yellow to yellow
green to green
c to blue
red to red
white to AUx??????
orange to E???????
What goes to O???????????????????
Old 12-14-13, 11:19 AM
Houston204's Avatar
Received 11 Votes on 9 Posts
Post the complete model number of your old thermostat.
A picture would also help...
Photo and image hosting, free photo galleries, photo editing
Old 12-15-13, 11:26 AM
Can't find model number anywhere on unit. However, with flashlight I was able to deuce that.....
white to e
orange to orange
yellow to yellow
green to green
red to red
c to blue
With only 6 wires , what does to AUX.???????????????
Old 12-15-13, 11:32 AM
Houston204's Avatar
Place a jumper wire between Aux and E if you do not have a wire for both.
