Trouble with connecting new thermostat
Old 03-09-13, 11:41 AM
Hi, my heatpump is a RUUD brand 2.0 ton air conditioning which is a combination system heat pump. This unit has model #UQKA-A024JK, serial #5528F440111074.
My old thermostat was the old type where you adjusted the temp with a lever. It had the following color wires: blue, green, white, yellow, and red which where connected to the same letters on the old thermostat.
I tried connecting to the new Honeywell RTH6450, but can't get the heat to run. I'm putting blue to AUX/E, green to G, white to W, yellow to Y, and red to R. What am I doing wrong?
Old 03-09-13, 01:37 PM
I figured out the problem.
Old 03-09-13, 01:42 PM
Received 2,965 Votes on 2,675 Posts
You're the man
Old 03-09-13, 01:44 PM
hvactechfw's Avatar
Received 4 Votes on 4 Posts
glad to hear, but here is the correct wiring
R = RED - 24V HOT
G = GREEN - FAN
Y = YELLOW - COMPRESSOR
AUX = WHITE - AUX HEAT
O/B = BLUE -REVERSING VALVE
Also, make sure you go into the advanced installation section of the manual to properly setup your thermostat for HP with aux heat.
