Air Handler
Old 04-12-13, 10:34 AM
C
Air Handler
After temp setting is met fan keeps running. If you move setting down one degree (A/C) it will stop. Is this tstat or something else. Just had coil cleaned.
casand38
Old 04-12-13, 11:07 AM
Received 4,051 Upvotes on 3,634 Posts
Welcome to the forums.
That's actually pretty strange as usually the AC and fan shut off together.
Based on your turning it down one degree would suggest a thermostat issue.
Old 04-13-13, 06:40 AM
Houston204's Avatar
Received 95 Upvotes on 88 Posts
If the fan is control by a sequencer the fan will run for up to 90 seconds after demand from the thermostat is removed.
Some thermostats have the option to delay the fan as well.
This function can increase the efficiency of the system but will increase the humidity in the space as well.
Did this problem just start?
