Thermostat settings for Honeywell unit
Old 04-15-13, 05:23 PM
B
Question Thermostat settings for Honeywell unit
I am not sure how to program my thermostat, it is a Honeywell RTH7500D. I am not sure what heat pump setup I have, the manual is asking to set one of these options:
1 Heat/cool: Gas, oil or electric heating with central air conditioning.
2 Heat pump: Heat pump without backup or auxiliary heat.
3 Heat only: Gas, oil or electric heat without central air conditioning.
4 Heat only with fan: Gas, oil or electric heat without central air conditioning.
5 Hot water heat only (no fan): Gas, oil or hot water heat without central air conditioning.
6 Cool only: Central air conditioning only.
7 Heat pump: Heat pump with backup or auxiliary heating.
8 Heat/Cool Multiple stages: 2 heat stages (wires on W and W2), 2 cooling stages (wires on Y and Y2).
9 Heat/Cool Multiple stages: 2 heat stages (wires on W and W2), 1 cooling stage (wire on Y).
10 Heat/Cool Multiple stages: 1 heat stage (wire on W), 2 cooling stages (wires on Y and Y2).
I have a heat pump, NHP230AKA1 (Tempstar 12) and an air handler in the attic (not sure if this matters) here are the wires to the thermostat:
C-blue
G-green
Y1-yellow
O-orange
R-red
W2-white
Any help is greatly appreciated, thanks!
Old 04-15-13, 06:25 PM
Houston204's Avatar
Received 95 Upvotes on 88 Posts
Function 170 = 7 (Heat pump: Heat pump with backup or auxiliary heating.)
190 = 0
set all heating CPH's to 3
Old 04-16-13, 09:14 PM
B
Thank you for the reply! What heating CPH's?
Old 04-17-13, 02:49 PM
hvactechfw's Avatar
Received 4 Upvotes on 4 Posts
Did you read the manual? Obviously not, cph is described in the installers section of the manual that is required to be read and followed to properly install your thermostat. Please refer to your manual for the proper function number and set them all to 3.
