Heat pump conversion issue!!
Old 04-15-13, 07:53 PM
F
So my a/c tech, being the jack wagon he apparently is, wired in a new control board & unhooked the heat pump all together (wires unhooked every where). I put in a conventional tstat & the heat works but not the air. I would like to wire it back in as a heat pump but I'm not positive where it all goes. The g-g r-r y-y I get but from the tsat to? Is it the control board then the heat pump kit (which is on top of the air handler) I don't know much about hvac units but I can't imagine that is hard to do. Any assistance would be awesome as I really hate to call him back out or have another tech clean up his mess. It's a trane xe 1200 heat pump. I don't really get schematics but I can do simple wire diagrams/instructions.
Old 04-16-13, 01:01 PM
hvactechfw's Avatar
Received 4 Upvotes on 4 Posts
We need more info on your system. Do you have aux heat? If so, what type, gas or electric? What are the make and model numbers of all your equipment?
