Fan Continues to Run
After my AC/Heat runs, the fan stays on. It blows warm air (not hot or cold) during this time. It continues to blow the warm air until the AC/Heat cuts on again. The only solution I found to get it to stop blowing is to heat the furnace at a certain spot. It works every time. I know there has to be a better permanent fix for this. Any ideas?
My thermostat is about 2 months old, but it did this with the older thermostat. The unit is about 10 years old.
Thanks
Thanks
Like Kevin said it sounds like a sticking relay or control. A picture would help immensely. If you are just heating the outside cabinet of the furnace..... take the service cover off and see what it is your heating.
