blower motor keeps overheating
Old 05-30-13, 01:27 PM
I have a vacation house in west Virginia and last year I think the motor went ouI smelled an electric burning smell and heard humming coming from furnance. It is a Lennox e11q electric furnance I believe. Didn't really check anything out since we were closing down for season. I ordered new motor which is exactly the same. Nothin is different hooked everything this up the same exact way and when I turn on everything works then after about 10 seconds I smell a burning smell and the house is filling with smoke and the motor is really hot can't touch for a split second without burning my hand. I read online that it could be the capacitor and I just picked on up from grainger. The old capacitol has two purple wires and a green wire that I think is a ground. The new capacitor only has two terminals can I still use that cause that is the only one I can on the motor it has cap. 5.00/370. Also could a bad capacitor cause the motor to overheat.
Thanks
Old 05-30-13, 06:13 PM
hvactechfw's Avatar
Received 4 Upvotes on 4 Posts
yes a bad capacitor can cause a motor to overheat, and you should ALWAYS replace the capacitor when you replace a motor. is that the cause? That is hard to say unless you start talking some voltage readings.
Old 06-02-13, 07:59 AM
Ok I will replace capacitor hopefully it didn't ruin motor. I only had running for prob about 5 mins. With the capacitor on the motor it says 5.00/370 I went to grainger and picked one up. The old capacitor has three wire running to it. 2 purple wires and a 1 green wire. The new.capacitor only has a place for 2 wires do I hook the 2 purple wires to it and the put the green to the mounting bracket. Thank you
Old 06-02-13, 03:31 PM
hvactechfw's Avatar
correct.... purple to capacitor and green to mounting bracket. What capacitor does the new motor call for.... not what capacitor value did the old motor use.
