Coil evaporator
Old 07-17-13, 04:22 PM
Coil evaporator
My hvac thec is going to change my evaporator coil because of faulty tvx valve wich supplier is giving no charge but here is sticky point.my old coil has a tvx but this one has a piston ,is this ok.it is a ruud 2.5 ton heat pump
Old 07-17-13, 10:04 PM
hvactechfw's Avatar
Received 2 Votes on 2 Posts
NO, you want a txv if you had one. Why is he replacing the whole coil and not just a txv?
Old 07-18-13, 01:54 PM
he is changing the whole coil because when he did change the tvx it was leaking right from the manufacturer i guess. He harped at supplier and supplier said he would send brand new coil evap.look we are getting terrible heat here 40c with humidex.also supplier sent evaporator with metering piston too big cause it was all he had in stock and would send right metering piston in a couple of days.hvac thec said supplier tech said it would not make much difference in cooling mode.now my heat pump is cooling only hvac tech said compressor is flooding a bit by his pressures.not only is suction line sweating but compressor is also sweating.QUESTION ,can this damage my compressor. THANKS IN ADVANCE
Old 07-18-13, 02:57 PM
hvactechfw's Avatar
Yes. That can damage the compressor.
Old 07-18-13, 06:42 PM
what would be the proper orifice size onthis evapcoil. rudd 2.5 ton heat pump
Old 07-18-13, 07:27 PM
hvactechfw's Avatar
The one that the manufacturer spec'd for it..... If they spec'd a piston instead of a txv.
