Wiring inside a ruud
Old 09-01-13, 02:23 PM
G
Hi
I have a ruud that I just replaced the thermostat and I would like to have fan only ability, how ever it was never hooked up. The model is ugla-125a-at installed in 1990. Where does the green wire go inside the furnace?
Old 09-01-13, 04:19 PM
F
Received 35 Votes on 27 Posts
The green wire from the thermostat goes to the G terminal on the thermostat connection board inside the furnace. It will have R, W, G, and Y terminals but not necessarily in that order. It may also have a C terminal.
Old 09-01-13, 08:04 PM
G
I really hope I would not miss a terminal that has r, y, g, w, and maybe c. So what i see is the red attached to one side of a transformer and white is attached to a thing that the gas line goes through with the pilot light. I have tried to attach pics please that me know if they work and if i'm looking in the wrong place for a terminal.
thank you.
Name:  nates ipod 004.jpg
Old 09-01-13, 08:12 PM
Received 1,020 Votes on 946 Posts
I couldn't find the wiring diagram for your unit there but it looks like you don't have a fan control center.
Is that just a furnace......no A/C ?
Old 09-01-13, 08:23 PM
G
No ac. Post too short so adding text.
Old 09-01-13, 08:30 PM
Ok.....you fan is now only controlled by that device in the second picture. It looks like a round silver disc over the gas valve. That's the blower temperature control. It closes the 120vac circuit to the blower when the heating plenum gets hot.
You would have to add a fan control center. It's a transformer and relay package in one unit. I'm guessing it would run about 100 bucks.
If it's something you want to install we can walk you thru it.
Old 09-01-13, 11:23 PM
F
That must be a pretty old furnace. While PJ's comments are correct you could probably add remote fan control for less than $25 by simply adding a relay powered from the existing transformer. I'm pretty sure you can get a suitable relay from Radio Shack but if not they are readily available. Biggest problem is that you will pay more for shipping than for the relay.
Old 09-02-13, 12:29 AM
Furd has a great idea. You could just use an hvac 24vac relay. They're all over places like eBay.
Let us know what you want to do.
