Can 4 ton Trane XL16i be used with 3 1/2 ton indoor unit?
Old 10-30-13, 10:56 AM
I had a new 4 ton trane XL16i unit installed two years ago. I recently discovered that the indoor unit that was installed with the 4 ton outdoor unit is 3 1/2 ton. I was wondering if this could impact the unit's ability to cool, because this unit will not cool my home on very hot days (90 degrees). Also, this system replaced a 5 ton unit. I was told the 4 ton would be more efficient because it would not cycle on and off as often as the 5 ton unit.
Old 10-30-13, 11:36 AM
Houston204's Avatar
Received 14 Votes on 11 Posts
Post the complete model number of the indoor unit.
Old 10-30-13, 08:00 PM
Indoor unit model number is: TAM7AOC42H31SAA
Outdoor unit model number is: 4TWX6048E1000AA
Old 11-02-13, 07:34 PM
Houston204's Avatar
http://www.trane.com/CPS/Uploads/Use...6_02012013.pdf
Page 10 of the TAM7A042 air handler manual airflow chart has it listed with 4 ton units.
I couldn't find anything on the latent and sensible heat capacities of that match.
Old 11-07-13, 08:49 AM
3 1/2 ton indoor Trane Unit
Thank you very much for this information.
