No blower with heat
Old 11-04-13, 01:47 PM
Question No blower with heat
my blower wont come on with the heat,but comes on with the ac,,,,help.....
Old 11-04-13, 01:52 PM
Received 59 Votes on 55 Posts
George: Welcome to the forums. I moved your question into its own thread for better visibility.
Hang tight, one of the pros should be along shortly.
Old 11-04-13, 05:28 PM
Received 478 Votes on 448 Posts
George.... post the make and model number of your furnace. You may have to remove the front cover to see it. There will be a metal plate or tag.
Depending on your unit you may have a defective fan/limit control.
Old 11-04-13, 08:27 PM
Houston204's Avatar
Received 14 Votes on 11 Posts
Have you replaced your thermostat since last winter?
If so, did you configure the stat to match your system?
Old 11-05-13, 01:02 PM
yes i did put a new thermostat last winter,the model number for the furnace is E2EB-012 H-A.....
Name on front cover says,,,intertherm........name on bottom of tag says nordyne.......
heat pump model #(218,024)(030,036)(042,048)
Old 11-05-13, 08:02 PM
Houston204's Avatar
Post the make and model of your new stat.
