Replacing thermostat
Old 11-13-13, 03:42 PM
Hi
I am trying to replace a heat pump thermostat. The new thermostat is honeywell 6000 pro. The old thermostat wires are; Y, G, R, O, C, E, W2.
The sockets in the new thermostat are; RC, R (with a connecting jumper), Y, C, O/B,G, AUX/E, L.
All the wires are obvious apart from the W2 which does'nt have an equivalent. I read somewhere that it should be connected to AUX/E together with the E wire. Is that true? If not, how to connect it?
Thanks
Ken
Old 11-13-13, 08:13 PM
Houston204's Avatar
Received 14 Votes on 11 Posts
Using both wires would increase comfort on very cold days.
Taping off the old E would be more efficient.
I would tape off the old E if Aux has at least 10 kw, but I'd bet NC is a colder climate than TX.
Old 11-13-13, 11:07 PM
Thank you.
Just to be sure. Can E and W2 wire both be inserted together in the Aux/E connection?
Ken
