Trane Ground Source Heat Pump Compressor Won't Start
Old 11-24-13, 07:55 PM
Thanks in advance for your help. I'm trying to get some heat in the house on a cold night. This is a Trane ground source unit, circa 2000. It's model number is GSUF048. This morning the unit's fan was running but no heat. The 2 amp fuse was open. I replaced it and cycled the power on the unit. Same story but the new fuse has not failed. At this moment the compressor and water pumps do not respond to a call from the thermostat but the fan turns on. I can manually force the compressor and pumps on from the relay. I thought it might be a bad transformer, but no dice. Replaced and same story.
Any ideas would be appreciated. I have a volt meter and can perform basic troubleshooting operations.
Old 11-24-13, 08:31 PM
Received 474 Votes on 444 Posts
Welcome to the forums.
There aren't many people around familiar with the geothermal systems.
I couldn't find any useable info like schematics on the system.
Maybe Houston (HVAC mod) has a better idea.
Doesn't that system have some type of re-heat system like electric coils for backup ?
Old 11-24-13, 09:05 PM
Emergency Heat
Hi PJMax,
Yes, the system is equipped with emergency heat coils. The ground source systems are not fundamentally different than the air-to-air systems as I'm sure you're aware. I was just thinking there may be some safety switch or reset switch of which I'm unaware. I know diagnosing such systems remotely is difficult, I just thought I might catch a break and be missing something simple.
All the best,
Gator
Old 11-24-13, 09:30 PM
I've worked on the systems but I had the wiring diagrams for them on site. I don't have any with me or I could point you in a positive direction.
Old 11-24-13, 10:44 PM
Houston204's Avatar
Received 14 Votes on 11 Posts
http://www.trane.com/webcache/un/wat...2_07011998.pdf
I see a normally open and a normally closed stat in line with that 2 amp fuse.
I'd check the wiring to them as well since the fuse blew.
Does you unit have a variable speed blower or a PSC blower?
This is the variable speed diagram...
Old 11-25-13, 06:52 AM
Variable
Houston,
It's a variable speed fan.
Old 11-25-13, 10:45 PM
Houston204's Avatar
Measure for 24 volts AC between R and C.
If it is present, give it a cooling demand and measure for 24VAC between Y and C.
