Heating Help Needed
Old 11-29-13, 02:15 PM
Heating Help Needed
I noticed yesterday when I went out back my outdoor unit fan is not spinning while on Heat. I only heard the compressor running. So I turned off the heat to the thermostat and made sure it was off. So i took the cover off and manually pushed in the contactor and both the fan and compressor kicks on. So I am stuck here with no heat.
If someone can help me out please that would be wonderful
Old 11-29-13, 02:27 PM
Houston204's Avatar
Received 14 Votes on 11 Posts
The outdoor fan stops for a while when a heat pump goes into defrost mode.
Was your system not heating before you noticed this event?
