Set point vrs Aux heat
Old 12-07-13, 12:29 PM
Mike1555's Avatar
If I want to turn up the heat without the Aux Heat (electric) coming on, I can only bump it by 1 degree. 2 degrees and the aux is on. I stopped programming the temp to go down at night since in the morning Aux heat is bringing me back to set point. This is normally a 6 hour period, figured??? I am saving $ by just keeping it @ one temp?? 13yr old Bryant HP thermostat = Bryant tstatbbprh01-b
Old 12-07-13, 12:48 PM
Houston204's Avatar
Received 14 Votes on 11 Posts
Yes, you are saving money by keeping the heat strips from energizing when recovering from a setback temperature setting.
You can use setback temps in cooling mode to save money, but not heat mode, with heat pumps.
