Heat Pump Fan Not Spinning
Old 02-03-14, 03:22 PM
C
Smile Heat Pump Fan Not Spinning
Hi Forum!
My heat pump fan does not spin. If I turn it off and try to spin it, it turns freely, but with it powered up, it turns tight. The cap seems to be OK; no bulges.
Is my motor shot?
Thanks!
Mike
Old 02-03-14, 05:40 PM
Houston204's Avatar
Received 17 Votes on 14 Posts
A capacitor can fail without swelling.
Is the motor getting 240 volts AC?
Old 02-03-14, 05:49 PM
C
Yes; motor has 240V. It locks up when power is applied, and turns freely with switch off. Could this be the capacitor?
Thanks!
Old 02-03-14, 06:33 PM
Houston204's Avatar
Yes, chances are higher that you need a cap than a motor.
Does your meter measure Ohms?
http://i151.photobucket.com/albums/s...OhmReading.jpg
