Converting Honeywell T8411R to Honeywell TH8320
Old 02-13-14, 12:05 PM
R
I am moving my downstairs thermostat to replace the upstairs one. The old one is a T8411R to a TH8320 programmable. The downstairs unit is gas heat and A/C, and the upstairs is 2H/1C heat pump with auxiliary heat.
Current config on the 8411 is
G=green wire
C=blue wire
R=red wire
W1/Y jumpered = yellow wire
L=black wire
W2=white wire
E=no wire
B=no wire
O=orange wire
TH8320 wiring config says I should have:
L=Equip Monitor
E=Emerg Heat relay
Aux = Aux heat relay
Rc/R jumpered = power
O/B = changeover valve
Y=Compressor relay
G=Fan relay
C=24VAC common
S1 and S2 optional outdoor/remote sensor
It also says Install field jumper between Aux and E terminals if there is no emergency heat relay. Do I need to do this?
It also says I need to set O or B in installer setup for the O/B.
What wires should go to the connectors on the 8320?
Old 02-13-14, 06:31 PM
Houston204's Avatar
Received 17 Votes on 14 Posts
G=green wire
C=blue wire
Rc/R=red wire
Y = yellow wire
L=black wire
Aux & E=white wire (Use a small piece of stat wire for a jumper)
O/B=orange wire
You must also configure the stat for heat pump with Aux heat.
Set function 170 to 7
190 = 0
Old 02-14-14, 06:38 AM
R
Thanks. Since the new t-stat has aux and compressor lockout settings, should I adjust those? How can I tell if my HP has an external temp wire?
Old 02-14-14, 12:16 PM
R
Maximizing efficiency honeywell visionpro with heat pump
I figured out I don't have a temp sensor.
How do I maximize heat pump efficiency? And how can I tell if the compressor is heating without the aux?
Old 02-14-14, 04:58 PM
Houston204's Avatar
Avoid setback temperatures in heat mode to avoid causing the expensive electric heat strips from running as much.
You can tape off the black wire that is on L and place a jumper wire between Aux and L to see when Aux heat is energized if you do not see the LED light up already.
Very few outdoor units even have an L terminal for fault light indication. Do you know if you have an L terminal in your outdoor unit?
