Defrost Board
Old 02-13-14, 10:57 PM
K
Defrost Board
Defrost Board
I replaced Blower Motor and connected white wire to contactor, black wire to defrost board, it didn't work . connected black wire to contactor and it worked but it wouldn't defrost. I am thinking defrost board needs replaced. would that be correct to connect black wire from blower motor to fan side of defrost board. I sure would hate to burn the defrost board
Read more: http://www.doityourself.com/forum/he...#ixzz2tHDmGbdu
Old 02-14-14, 11:19 AM
Can you post model # and make? One of the motor leads needs to go to the capacitor.
Old 02-14-14, 10:55 PM
K
York, 10 seer, Heat pump, It has two brown wires, one brown and white, one brown, to capacitor. if I put black on defrost board where is says fan it doesn't work.
Old 02-14-14, 11:47 PM
Received 1,036 Votes on 960 Posts
I'm trying to figure out why you started another thread on the same subject ?
Maybe the fan doesn't work because the board is in defrost mode when you're testing.
