change to nest
Old 02-23-14, 01:07 PM
B
change to nest
I am upgrading to a nest thermostat. I have an all electric house with a heat pump. my old thermostat had a w1 and a w2 wire. the w1 is my aux heat, but what do I do with the w2 wire?
Old 02-23-14, 05:58 PM
Houston204's Avatar
Received 17 Votes on 14 Posts
We require more information.
I see a W1 and a W2 terminal on the Nest.
Post the make and model of the old stat.
Post the terminal = wire combination of the old stat.
Old 02-25-14, 02:47 PM
B
yes, but when I put the W1 into W1 and W2 into W2, the Nest gives me an error, it can't handle a dual pump system. Of course I only have a single heat pump system..
Old 02-25-14, 04:15 PM
B
The old stat had an E/W1 and a W2. The model of the old thermostat is a Maytag part# 9186880
Old 02-25-14, 08:18 PM
Houston204's Avatar
Tough to diagnose that from here, W1 and W2 may be jumpered at the air handler.
Post the make and model of your old stat.
Old 02-26-14, 07:05 PM
B
No, not jumpered at the air handler. The air handler has a W1 and a W2 that these wires are connected to...
Old 02-26-14, 08:08 PM
Houston204's Avatar
Any ideas as to the make and model of the old stat?
