heat pump wire question?
Old 02-24-14, 02:28 PM
K
i just got there unit for my house , there no force air in the house before, this is brand new install.
i also never done it before, try to do it most i can , so when i hire the contractor , he does not asking too much
i wonder do i have to pull the thermostats wire outside where the heat pump is for wiring ?
furnace :GMH950904CX
heat pump :GSX130361
Coil: CAPF3636C6C
Old 02-24-14, 05:12 PM
Houston204's Avatar
Received 17 Votes on 14 Posts
http://www.alpinehomeair.com/related...%2012.2012.pdf
You want at least 6 conductors from the indoor unit to the outdoor unit with heat pumps, but that is not a heat pump.
The outdoor unit diagram shows 2 conductors required. I'd pull 3 or 4 conductor 18 gauge wire from the furnace to the outdoor unit with a conventional split system.
http://www.goodmanmfg.com/Portals/0/pdf/SS/SS-GMh95.pdf
Looks like you have a 2 stage gas furnace that does not support a 2 stage thermostat.
The diagram for the furnace shows 5 conductors from the thermostat to the furnace, but I would pull at least 6 conductor 18 gauge wire between the stat and the furnace.
Old 02-26-14, 02:27 PM
K
so basically i need 7 wire for thermostats . 2 out side for the heat pump and 5 inside for the furnace?
Old 02-26-14, 04:53 PM
Received 1,030 Votes on 956 Posts
It would be 5 plus one spare. The two that go to the compressor unit (not heat pump) go to the air handler where they are combined with the thermostat lines.
Old 02-27-14, 11:46 AM
K
thank , is very helpfullll
