basement is cold the circulatory pump not working It's a GE
Old 03-14-14, 03:27 PM
The boiler we have is old but the first and second floor is getting heat.
THe basement radiator are cold and the pump not spinning. i even bleed the radiator nothing happen.
the Pump is a GE ac motor
HP 1/8
MBD 5kh32EG129EX
RPM 1725
Size:  38.7 KBAttachment 28343Name:  20140314_164742.jpg
it looks like it's been there since the house was built.
what circulatory pump i should get to replace it ?
and if i get an higher hp pump does it make a different?
thanks in advance
Old 03-15-14, 07:26 AM
The most important thing is the rpm. Make sure you get the same rpm.
Old 03-16-14, 10:51 AM
why is that ?
i look online and saw those type of inline pumps are like 500 plus
should i just replace the motor or the entire pump?
i see the ge ac motors on ebay
Old 03-16-14, 11:31 AM
I would just replace the motor first. Have you checked volts to the motor? Maybe a bad connection? If you get a motor with more or less rpm you won't get the proper water flow ( GPM).
Old 03-16-14, 11:48 AM
the volt is 115
it was working during the winter then it stop and the basement is not heating up at all
