Loud fan humm, Trane XB13
Old 05-07-14, 11:53 AM
G
On a split system, the fan on the condenser makes a loud humming or whirring noise.
Trane XB13, 4TTB3024D1000AA
The fan has two blades, measures 23 1/2 inches.
I can remove the fan from the motor and start the unit, and it runs as quiet as can be - no noise from the motor. So the loud whirring sound is evidently coming from the fan blade itself.
Should I get a new blade? Would a 3-blade or 4-blade fan run more quiet?
Thanks
Old 05-08-14, 08:00 AM
T
Received 16 Votes on 12 Posts
When the blades are on the motor, it sees a load. With the blades off, there is no load on the motor. With that said, fan blades don't hum, electric motors can hum. (60hz)
The fan motor is probably at fault and may very well be on it's last days of usage.
Old 05-08-14, 08:54 PM
Received 1,203 Votes on 1,113 Posts
The fan blades and the venturi (fan opening) are designed to move a lot of air. You can't just replace the blade with a different style. If it was quiet and now it's noisy.... that would be the motor.
