Lennox 13HPX on AC tripping to the 5 min anti-short cycle
Old 07-19-14, 07:57 AM
I have a 2006 Lennox 13HPX in my shop and it worked great until last week. I walked in and the squirrel cage fan was running; but, the compressor was silent. Every few minutes, the compressor fan would kick on for about 30 seconds and then stop. The red and green lights were alternating slow flash (1 sec on 1 sec off) and according to the diagnostics code, this is a 5 min anti-short cycle delay. I tripped the power for a few seconds and checked the diagnostics and the lights were flashing simultaneously slow (normal). So, i restarted the system. The unit ran like it should (it was 102 deg F outside and the shop was up to ~80 on the inside. The exit duct close to the coil was ~65 (normal for this system). I came back about an hour later and the unit had tripped off again and was in the 5 min anti-short cycle delay again. If the unit sits long enough (several hours) it will indicate normal (slow simultaneous flash).
I would sure appreciate some suggestions as to what to test / troubleshoot. I am decent with electrical power, controls, hydraulics and mechanical. I enjoy learning and am ready to pull the fluke meter out - I just need to know what to check. Or if it could be a pressure issue, I can check that as well (just need to know the ranges).
Old 07-19-14, 09:55 AM
Houston204's Avatar
Received 17 Votes on 14 Posts
Check for melted wiring in the outdoor unit.
Take look at the contactor.
Turn off power to the outdoor unit and wait 2 or 3 minutes for the cap to bleed down. Take note of which wire is on Com, F, and Herm, unwire and check your capacitor.
Fluke uses this symbol on meters.
Old 08-16-14, 03:11 PM
user 10's Avatar
Received 41 Votes on 35 Posts
Monitor the system and check the error code right when the system shuts off - should tell you if there's a pressure issue. I think your unit is a heatpump - you most likely have a defrost board, not a simple time delay.
Old 08-17-14, 10:40 AM
Houston204's Avatar
When is the last time that the outdoor coil was cleaned?
It would be great if you could see it as it trips.
Name:  Lennox 13HPX.jpg
