goodman hpta18-60 thermostat replacement
Old 09-27-14, 09:34 AM
C
I have a hta18-60 thermostat and i hope to get some information from someone to replace it with a more modern thermostat please
thank you in advanced
p.s sorry for the bad pics
Old 09-27-14, 10:26 AM
Houston204's Avatar
Received 83 Upvotes on 76 Posts
Looks like you have a 2 heat 1 cool heat pump thermostat.
I'd take a look at the terminals to see if you have a C (24 volt common) wire.
Name:  Goodman HPTA18060.jpg
Old 09-28-14, 07:25 AM
C
i will turn off power to the a/c unit here is a sec and take thermo off wall to see if "c" wire
Old 09-28-14, 08:03 AM
C
i believe there is a "c" wire
Old 09-28-14, 08:45 AM
Received 3,478 Upvotes on 3,123 Posts
So..... you have a 2 heat 1 cool heat pump thermostat with a common.
Old 09-28-14, 09:08 AM
C
is that a common modern thermostat or do i need a special one
Old 09-28-14, 09:14 AM
Houston204's Avatar
Are you going to to look on internet sites or local hardware stores for a new stat?
I prefer the Pro Honeywell thermostats available on sites like Amazon because they give you more options like cycles per hour but your local hardware stores would be more convenient, especially if you had to return it for any reason.
The Retail Honeywell thermostats begin with an R.
These would support a multistage heat pump...
Name:  Home Depot Stats.jpg
Old 09-28-14, 09:29 AM
C
well thats awesome i thought that mine was ld and would never be able to change the stat to modern
Old 09-28-14, 09:48 AM
Houston204's Avatar
Remember to turn off power to the indoor unit before replacing the thermostat.
Touching C to R will pop a fuse or damage a transformer with power present.
Touching Y to R several times in a second is tough on the compressor with power present.
Old 09-28-14, 04:14 PM
C
wire color on that pic should be same for new stat right
Old 09-28-14, 04:45 PM
Houston204's Avatar
The black and white wires will connect to E and Aux but this will likely be the same terminal with the new stat.
