New baseboard heater wiring
Old 09-30-14, 11:03 AM
C
I purchased a new baseboard heater for a spare room (Dimplex LPC with built in therm). The old heater never worked so the wires were just closed off with nuts. I have 2 supply lines and confused as to which one to use for the install. I assume 1 is for a thermostat but both lines are cut just long enough for a heater on the floor. I have tried wiring each supply line and closing off the other with nuts, but I have no power to the heater. The instructions do say the connections must be made on the right side, but I am going on the left which does have a junction. Customer service for the company is non existent.
Old 09-30-14, 11:42 AM
Q
Received 1 Vote on 1 Post
What heater type is it and what do the instructions have? p.4 of this shows some wiring - in theory it shouldn't matter which side:
http://www.homedepot.com/catalog/pdf...c30ccb0f9e.pdf
In theory the wire from the floor connect black from the power to black on the heater and white (or red) from the power to red on the heter.
Old 10-01-14, 12:22 AM
Received 1,019 Votes on 946 Posts
The thermostat is usually in the same end that they recommend feeding it from.
You can feed it from either end though.
Since this is basically a new installation.... did you measure the voltage at the heater to see if it's 120vac or 240vac or are you just winging it ?
Old 10-01-14, 08:47 AM
C
Well I connected both supply lines to each connection and the breaker tripped, so I'm assuming the heater is only capable of 120.
A friend suggested I test each line with a multimeter for voltage. Also, the thermostat side has a bare line which should be connected to the hot feed. I guess I should just cap that off if I am not wiring on that side.
This is the heater. Maybe its a dud and has to be returned?
Dimplex | 500W Linear Proportional Convector - White | Home Depot Canada
Old 10-01-14, 08:52 AM
That is an excellent idea !
