Where is the C terminal?
Old 10-17-14, 09:01 PM
T
I have 5 wire cable that connects to my thermostat but the black (C) is not being used. I bought a new thermostat that requires the C wire. I traced the wire back to nothing at the furnace end. It's loose. Now, my question is where I should connect it at the furnace? There are R Y F and G. All but F is connected. Looking at the diagram, F is fault. Thanks in advance.Name:  IMG_2259.jpg
Size:  25.1 KBName:  IMG_2260.jpg
Size:  25.1 KBName:  IMG_2261.jpg
Size:  28.2 KBName:  IMG_2276.jpg
Size:  30.0 KBName:  IMG_2285.jpg
Old 10-17-14, 09:48 PM
Received 3,749 Upvotes on 3,362 Posts
Welcome to the forums.
Thanks for the pictures. I re-appropriated the schematic. Your C connection is the metal chassis of the air handler. You can use any screw or bolt near the terminal strip for your C connection.
Old 10-18-14, 10:18 AM
T
I unscrewed a bolt that was already attached to the chassis, placed the black wire there and screw it back. Connect the new Thermostat and it worked!! Thanks PJmax!!
Old 10-18-14, 10:41 AM
Thanks for stopping back and you're welcome
