Installed Honewell RTH7600D thermostat - Heat won't turn on!
Old 11-15-14, 12:44 PM
B
Question Installed Honewell RTH7600D thermostat - Heat won't turn on!
Furnace:
Goodman ARU049-00A-1A
With Honewell Universal Minizone for Bonus room
Wiring configuration:
R
W
Y
G
C
W2
Thermostat Settings:
170 - 9
180 - 1
190 - dosent ask
240 - 5
270 - dosent ask
300 - 1
Situation:
I changed my thermostat out this morning with the Honewell programmable model mentioned above. Now, the current temperature in the house is 65f but the thermostat is set at 74f. Only cool air blows from the vents so the fan is circulating. I also cannot seem to get the auxiliary heat to turn on since the switch. I have a bonus room with a separate thermostat that I did not change. The heat works when that unit is turned up? I know the issue lies in the setting but do not know what the correct configuration is. Please help!
Old 11-15-14, 01:35 PM
firedawgsatx's Avatar
Received 2 Upvotes on 2 Posts
Did you leave an "F" out of the model number? I suggest setting function 170 to 7 to see if 190 will show up. Then you should be able to set 190 to desired setting and configure the other functions.
