York furnace ruff model N1AHBO806A heat doesn’t work
Received 0 Votes
I have a heat pump outside GMC 2 tons USZ 130241B, 1 COIL 2 Tons Goodman ant 1 thermostat White Rodgers 1F95-1277.
The heat pump is working well ,my problem is when the temperature is to low outside and the heat pump can’t give no more heat suppose to start the furnace element the thermostat is asking for that I can see on the screen SYSTEM ON +2 but seems to have no power on the element. I check the element seems ok.
I have this board all the entry power seems to be present
Here is the link to the manual I think
http://www.master.ca/documents/0NAHRepairParts-0303.pdf
